TwinTurbo.NET: Nissan 300ZX forum - Vacuum leak would cause you to run lean
Subject Vacuum leak would cause you to run lean
Posted by -Grimm- on October 14, 2013 at 3:58 PM
  This message has been viewed 225 times.
In Reply To engine was up to temp i went for a short drive prior posted by Khronik on October 14, 2013 at 03:25 PM
Message Getting more air than is metered/accounted for
Sounds more like an O2 sensor issue. Do you have any ECU talk /diagnostic programs?
Even the cheapest programs have a 'scope' feature that makes sensor diagnostics much easier.
For instance here is a picture of when my NA O2 sensor was bad (about 3 years ago)
You can see LH running sinusoidal like it should, RH is flatlined.
Here is a picture of my failed O2 sensor. The tip was broken causing erratic readings.
